Turbomachinery issues again, Pressure overprediction
Old   February 26, 2010, 01:04
Default Turbomachinery issues again, Pressure overprediction
Sherif Kadry
sherifkadry is on a distinguished road
I was looking for some turbo advice. I had earlier posted about my 3 stage axial turbine model that was initally overpredicted massflow. Well I managed to correct this by refining the mesh extensively. Now the odd thing is the pressure at various measurement points do not change much when compared to coarses discretizations. Both, compared to experimentally are strongly overpredicted, yet the massflow for most cases are within 2% and the total to static efficiency is within 1.5 % when compared to experiment. I cannot understand this, I would have thought the pressures would be a little closer to experimental results, if other parameters are closer. It seems all the pressures when compared to experiment are offset by a certain value that slighty increase as the point moves axially. I have even tried two different turbulence models a 2 equation and a RSM model yet the pressures are still overpredicted. Any thoughts anyone?
sherifkadry is offline   Reply With Quote
pressure, turbomachinery
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure Condition sidd Siemens 0 April 2, 2007 09:31
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
Pressure Boundary Problems Chris Siemens 2 June 21, 2005 08:20
