March 3, 2010, 23:20 |
extremely low residuals
ranjith
Rep Power: 16 |
I am doing an FSI simulation of flow through a micro pore(in a tissue engineering cartilage). The problem is that the residuals are very low of the order of 10 raised to -21 and they converge in the first iteration itself. when i view the result I find the velocity also too small of the same order(10 raised to -21) and this isnt what I am expecting. My simulation setup is as follows - I have a cube made of the scaffold material(youngs modulus .1 MPa) Inside the cube there is spherical pore filled with water with two openings to two sides of the cube. I apply a linear pressure on one face of the cube from 0 to 4000Pa. The opposite face is constrained by a fixed support. Please help me with this Ranjith |
March 4, 2010, 02:24 |
Lance
Rep Power: 22 |
check the dimensions of the fluid and solid domains. I had the same problem when my fluid model was specified in [mm] and my solid in [m], i.e. 1000 times bigger. Lance |
March 4, 2010, 05:45 |
Rep Power: 143 |
Could also be because you have the units wrong on the driving function. Could also be your timestep is far too small (this is unlikely). But most probably it is a setup error.
Display Modes | |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
Drag and Lift forces extremely low | João Lourenço | FLUENT | 4 | January 28, 2008 13:25 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
residuals | Karl | CFX | 2 | June 24, 2003 23:13 |
