extremely low residuals
Old   March 3, 2010, 23:20
Default extremely low residuals
ranjith
ranjith is on a distinguished road
I am doing an FSI simulation of flow through a micro pore(in a tissue engineering cartilage). The problem is that the residuals are very low of the order of 10 raised to -21 and they converge in the first iteration itself. when i view the result I find the velocity also too small of the same order(10 raised to -21) and this isnt what I am expecting.
My simulation setup is as follows - I have a cube made of the scaffold material(youngs modulus .1 MPa) Inside the cube there is spherical pore filled with water with two openings to two sides of the cube. I apply a linear pressure on one face of the cube from 0 to 4000Pa. The opposite face is constrained by a fixed support.
Please help me with this
Ranjith
ranjith is offline   Reply With Quote
Old   March 4, 2010, 02:24
Lance
Lance is on a distinguished road
check the dimensions of the fluid and solid domains. I had the same problem when my fluid model was specified in [mm] and my solid in [m], i.e. 1000 times bigger.
Lance
Lance is offline   Reply With Quote
Old   March 4, 2010, 05:45
Could also be because you have the units wrong on the driving function. Could also be your timestep is far too small (this is unlikely). But most probably it is a setup error.
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
Drag and Lift forces extremely low João Lourenço FLUENT 4 January 28, 2008 13:25
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
residuals Karl CFX 2 June 24, 2003 23:13
