confused on messages after solver has terminated |
February 21, 2010, 20:29 |
Rep Power: 16 |
Dear all,
i'm confused on the messages after solver has terminated. It does indicate that my simulation has reached the desired residual criteria and has stop the solver as shown below. ================================================== ==================== OUTER LOOP ITERATION = 368 CPU SECONDS = 2.165E+04 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.97 | 4.5E-06 | 2.9E-04 | 2.9E-02 OK| | V-Mom | 0.97 | 2.1E-06 | 1.2E-04 | 3.6E-02 OK| | W-Mom | 0.96 | 9.8E-06 | 8.4E-04 | 1.8E-02 OK| | P-Mass | 0.98 | 4.4E-07 | 2.4E-05 | 5.0 9.3E-02 OK| +----------------------+------+---------+---------+------------------+ | H-Energy | 0.98 | 7.1E-06 | 7.1E-04 | 1.6E-02 OK| | T-Energy | 0.98 | 4.2E-07 | 7.8E-06 | 5.8 1.6E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.99 | 5.3E-06 | 4.4E-04 | 5.8 2.4E-03 OK| | E-Diss.K | 0.97 | 1.8E-06 | 1.4E-04 | 12.9 6.9E-06 OK| +----------------------+------+---------+---------+------------------+ CFD Solver finished: Sun Feb 21 23:08:35 2010 CFD Solver wall clock seconds: 2.1693E+04 Execution terminating: all residual are below their target criteria. BUT then, going further down the message page, it claims there's an error. +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Error disconnecting from shared license socket. | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine RUNF3D | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The results from this run of the ANSYS CFX Solver have been | | written to E:\Yi CHENG\cylinder with cooling | | channel\hseAsm11gridRibsL30H3_001.res How should i treat this result? is this result acceptable please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
April 21, 2010, 17:58 |
J. D. Aurand
Rep Power: 15 |
Did you have any monitor points? If you did, did they level off with acceptable variances? I don't know a lot about the error messages, but my first thought is that there was a problem with wrapping up the partitioner or returning the license to the pool. If the monitor points are steady, I would take the results as acceptable, but still be somewhat skeptical (i.e. if another run is vastly different, but converges and everything else looks good, go with those results).
Display Modes | |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
Solver Error messages!! | Rajit | FLUENT | 3 | August 27, 2006 16:28 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
