Problem with probe
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 15, 2010, 02:53
Default Problem with probe
jfa
Jörg
jfa is on a distinguished road
Hello!
I have a little problem regarding to the probe-function in Ansys CFD-Post.
My intention is to determine the velocity of my model in several discreet points given by x-, y- and z-coordinates.
I want to use - correct me if I'm wrong - the probe function with the following syntax:
probe(velocity)@(0;0;0)
Unfortunately I don't get a solution, I think the location-coordinates-syntax is wrong.
What is the right syntax?
Thanks in advance!
Best Regards, Jörg
jfa is offline   Reply With Quote
Old   March 15, 2010, 05:36
Make a point object on the front page of CFD-Post. Then the probe(velocity)@Point 1 function should work.
Old   March 15, 2010, 07:44
jfa
Jörg
Yes this works...Thanks!
But this isn't useful for many points. I have to probe approx. 8000 points. I can't create them all manual. And Point clouds aren't "probe-able".
My target is to get the velocity of each point of an closely point grid of an rectangular plane, ideally as an table like this:
| X-coord. | Y-coord. | Z.-coord. | velocity |
Please help me!
Thanks.
Old   March 15, 2010, 14:20
Turn the session recorder on and record a session file. While recording, make a point object and stop recording. Look at the session file in a text editor - you can now edit (copy/paste) the session file to generate as many points as you like. If you feel really clever you can even use a perl script loop to generate zillions of points in a small loop.
To export the data you simply use the file/export command and select the locators (in this case the points) and the variables you wish to export.
Melikmemmed likes this.
Old   March 16, 2010, 02:25
jfa
Jörg
D-Oh!
I have never seen the file->export option before. Now it is really easy.
Sometimes I don't see the forest because of all the trees....
Best thanks!
-to be closed-
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with probe Yolanda CFX 0 May 17, 2006 06:27
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
