Best practice for sand/water mixture ??
Old   March 22, 2010, 05:02
Default Best practice for sand/water mixture ??
Michiel
Michiel is on a distinguished road
I would like to study the flow inside a dredging pump. The fluid is water which contains a high concentration of sand (30%-60%). My first thought was to use the particle transport model. But after some reading and a simple test calc this seems to take a long time to solve the problem.
Besides the particle transport, how can I model this behaviour? And which approach should be most efficient?
Michiel is offline   Reply With Quote
Old   March 22, 2010, 14:10
At such a high particle loading the Eularian approach looks attractive. Have you tried that?
Old   March 23, 2010, 06:00
Michiel
Yes, I'm setting up some trail analysis with a multiphase model. First result looks good.
I don't know exactely how to define the material properties for the sand part and how to couple the two fluids. It seems there is not much difference between defining the sand as dispersed solid or dispersed fluid. I think because of the material properties have more influence, am i correct??
It looks like this approach will do the job.
Old   March 23, 2010, 06:05
I don't have enough knowledge of the details of each of those models to comment. My only recommendation would be to look at examples and tutorials of similar situations. For instance the fluidised bed models may be of interest, that may be useable in your case. At least it will give you some tips on how to do things. I did a multiphase course years ago on this sort of stuff but I don't use any heavy particle load flow models so I have forgotten it all - but I can recommend the advanced multiphase course if you get a chance to go on one.
Old   March 24, 2010, 09:40
Michiel
Thanks for the tips!
Besides information on fluidised beds I also found some nice information about slurry flow modeling. At the following site you can download some papers on this subject: http://works.bepress.com/sandip_lahiri/
It seems that the model which is best for my application is described by the Phd thesis written by Sandip Kamur Lahiri. I looks like I have to do some reading these days...
Old   March 26, 2010, 07:38
jsm
JSM
jsm is on a distinguished road
Hi Michiel,
Thanks for the link for slurry flow. It is more useful to me
With regards,
JSM
jsm is offline   Reply With Quote
mixture template co2 FLUENT 8 December 19, 2016 01:25
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 22:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 06:04
Burning a CH4-H2 Mixture Jonathan Lemay CFX 2 November 12, 2007 17:01
doubt about background fluid in multico mixture... Giosuč Siemens 0 June 11, 2004 05:18
