March 26, 2010, 03:59 |
Validity of Local Time Scale Factor
Rep Power: 16 |
Hi everyone!
I'm modeling a mixing process of high speed and slow speed fluids (ratio of 20:1). I often get good convergence using time scale factor which is I think more appropriate in my case because of the difference in velocities. However, Sir Glenn and Sir Robin and others have recommended in this forum that such case should be run again using physical time scale but I usually end up having fluctuating residuals if I do this. In ANYS12 Manual, there is still no mention of "unreliable" solution using local time scale factor. Is it really "unreliable"? Thank you, kuh |
March 26, 2010, 05:10 |
Rep Power: 143 |
Yes, it can be unreliable. So yes, you really need to run the last 10 iterations or so using physical timescale so the flow time scales can be sorted out. Note you can do this as the simulation progresses so no need to stop and restart (with edit run in progress).
I don't get called sir very often |
March 26, 2010, 08:32 |
Hi
#3 | |
Dynampally Pavitran
Rep Power: 16 |
March 26, 2010, 08:36 |
Rep Power: 16 |
Thank you very much Sir Glenn for your urgent response. I didn't know that we can "delete a parameter" from the edit run in progress option. I think "Sir" is just appropriate since you have our source of knowledge for many years now. Thanks again.
March 26, 2010, 15:15 |
#5 | |
Rep Power: 143 |
http://www.cfd-online.com/Forums/cfx...le-factor.html |
local time scale factor, mixing |
Dynamic moving mesh | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 64 | June 7, 2012 10:04 |
advection time scale | Tanveer ahmad Rubani | CFX | 1 | February 24, 2009 16:16 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
time averaged heat transfer in oscillating flow | Matthieu Ubas | Main CFD Forum | 2 | November 5, 1999 14:20 |
