[Sponsors] | |||||
Rep Power: 6 ![]() |
Hello!
I want to calculate the boundary layer thickness on a plate. For this I have created several Lines vertical on the plate an now I want to know the altitude atop the plate where the velocity reaches 99% of Uinf for the first time. Is there any function that can tell me the coordinates of a certain variable on a Line? Thanks in advance |
Dmitry Volkind
Rep Power: 5 ![]() |
If Uinf is constant and Y is my plane normal and starts with zero at the wall, I would use CEL:
MyFunction1 = v - 0.99*Uinf MyFunction2 = step (MyFunction1) Then I would make a plot MyFunction2 = f(Y) Axis segment where MyFunction2 = 0.5 is my boundary layer thickness +-tolerance It's the first thing that comes to my narrow mind, still I think there must be a better way. |
Hey Dvolkind,
Thanks for your reply! I have tried your solution but its still not working. I get the Warning: "No Data exists for variable "my variable..." I am working on that keep you updated. cheers |
Rep Power: 60 ![]() ![]() ![]() |
The problem with Dmitry's approach is it does not interpolate correctly between nodes. If you are going to do a lot of this I would export the nodal values along the line and do it either with a program or in excel/matlab/whatever. Then you will be able to batch a few of them together to do it more efficiently.
Hey Glenn,
Thats what I am about to do. Export all the data to matlab. However I thought maybe there is a easy solution for this first step in Ansys. Thanks Camoesas |
Bruno
Rep Power: 8 ![]() |
Can't you just create an isosurface of 0.99*Vinf and then export this surface? When calculating the isosurface Post will interpolate values fine.
(remeber to clip it to the are you're interested in) |
Dmitry Volkind
It's probably too late, but I think extracting a polyline from a velocity contour plot is a good idea.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
| GMSH and OpenFOAM | derath | OpenFOAM Mesh Utilities | 44 | September 4, 2008 05:09 |
| BlockMeshmergePatchPairs | hjasak | OpenFOAM Native Meshers: blockMesh | 11 | August 15, 2008 07:36 |
| BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Native Meshers: blockMesh | 3 | June 29, 2008 21:24 |
| Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
