April 3, 2010, 15:29 |
Boundary Condition (variable Umax)
Rep Power: 17 |
Hi Pals
I wanna set an expression for inlet boundary condition. that's it: u=Umax(t)[1-r^2/R^2] No problem so far! but I want it to pick up the Umax(t) from the specified cyclic curve in every timestep! How can I do that? thanks alot |
April 4, 2010, 07:35 |
Rep Power: 143 |
If you know the Umax function then write it as a CEL expression. Otherwise use an interpolation function to define the Umax expression.
April 4, 2010, 10:19 |
Rep Power: 17 |
Thank you soooo much
I appreciate your help. I think I should use an interpolation function. Best regards |
Calculated gradient boundary condition similar to gammaContactAngle | adona058 | OpenFOAM Running, Solving & CFD | 0 | September 26, 2007 15:23 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
Additional variable - wall boundary condition | flga | CFX | 2 | May 30, 2007 03:14 |
1 and 2 Order Boundary condition at the same place | CFD_Flo | Main CFD Forum | 4 | July 11, 2005 11:57 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
