Boundary Condition (variable Umax)
Hi Pals
I wanna set an expression for inlet boundary condition. that's it: u=Umax(t)[1-r^2/R^2] No problem so far! but I want it to pick up the Umax(t) from the specified cyclic curve in every timestep! How can I do that? thanks alot |
If you know the Umax function then write it as a CEL expression. Otherwise use an interpolation function to define the Umax expression.
Thank you soooo much
I appreciate your help. I think I should use an interpolation function. Best regards |
