Error writing transient results in FSI
Old   April 6, 2010, 09:20
Default Error writing transient results in FSI
Daniel Paukner
Pocket is on a distinguished road
i am trying to run a transient Fluid Structure Interaction on a rocket nosecone geometry consisting of 2 bonded solid bodies of different materials submerged in one fluid domain.
My predecessor got it to run in ANSYS 11 (at least his report says so), but i have to use 12.1 since there are supposed to be several improvements in the multiphysics field.
However, i get an error whenever the solver tries to write its first set of transient results:
| Writing transient file 1_CS_full.trn |
| Name : Transient Results 1 |
| Type : Standard |
| Option : Every Coupling Step |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Length of variables list is not consistant in parallel. Routine G- |
| ET_VARLST called from routine Write_Soln_Fcs. |
Google doesn't even know this error, and i myself have never encountered it before in any of my other FSI-Simulations (which only use one solid body).
I defined both exposed faces of the nosecone+can as one FSIN and coupled it to the fluid domain.
The Solver is running on a 4-Core XEON machine with 16GB Ram in local MPI.
Does anybody have a clue what this error message tries to tell me?
Is it a setup error or a mpi error?
If you need more info, i am happy to provide.
Thanks for your help,
Daniel
Pocket is offline   Reply With Quote
Old   April 15, 2010, 06:57
Daniel Paukner
Ok, it seems to be a MPI error. When i run the Simulation on 1 core, it works perfectly fine.
Daniel
Time averaging results from a transient run Flow Squad CFX 4 October 24, 2011 09:11
transient heat transfer - radiation model - implausible results thomasduerr OpenFOAM Running, Solving & CFD 0 July 13, 2009 10:03
Combining Transient results after a backup Dre CFX 9 February 18, 2008 08:43
intermediate results during a transient run Michael Skoblin CFX 1 September 25, 2006 14:00
Transient Results Ogbeni CFX 5 November 30, 2004 09:43
