Home > Forums > CFX
Incompressible flow
Old   April 16, 2010, 20:55
Post Incompressible flow
FM
Felipe Matos is on a distinguished road
Hi
I'm trying to simulate a incompressible steady-state flow inside a cilindrical tube. My regime is laminar, with no heat transfer. However, i'm not finding the compressibilty control, that is normally at Solver Control > Advanced Tab inside the CFX-Pre. Anyone knows how can I force the flow to be incompressible in such situation?
Thanks
Felipe Matos is offline   Reply With Quote
Old   April 18, 2010, 07:20
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
If you have defined your material density to be a constant the model will be incompressible. Alternately if you turn the heat equation off like you did that will also force it to do an incompressible simulation (unless you defined density as a function of pressure).
Thread Tools
Trackbacks are On
Reynold's number and incompressible flow Neil Main CFD Forum 3 October 24, 2006 08:11
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
pressure outlet BC for incompressible flow khaiching Main CFD Forum 6 October 15, 2005 02:58
Incompressible and compressible flow. John. Main CFD Forum 1 December 15, 2004 12:29
incompressible flow - prescribing pressure drop - how best to do it? M. Gerritsen Main CFD Forum 4 January 10, 1999 10:53
