Actuator Disk Model
Old   April 18, 2010, 16:29
Default Actuator Disk Model
Jialin Su
sujialin is on a distinguished road
I tried to simulate a ducted fan in a wing with the actuator disk model. But I couldn't set up the pressure jump boundary condition. So I just set the inlet of the actuator disk to the outlet boundary condition and the outlet of disk to the inlet boundary condition. And I put the same flow rate for them both. As a specified pressure jump boundary condition would correspond to a certain flow rate through disk, I believe my setup should generate the correct and unique solution for the case. Unfortunately the result does not converge very well. Have any of you folks similar experience?
My second thought is to set up a separate finite domain for the actuator disk and include a momentum source to generate a pressure increase. Is there any suggestion for this? Thanks.
sujialin is offline   Reply With Quote
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
