post processing tansient results
I have run a transient simulation of a turbine. Now I would like to postprocess. I have mad 100 timesteps and got .trn results for each one (about 23 GB total). How can I for example plot the time averaged temperatre in a plane (average of all the 100 timesteps)??? I opne the .res file in CFD-post, and than? How do I load all these .trn files into the CFD-post??? Thank you very much!!!! By the way: Does anybody know a good tutorial for this time averaged problem?? Cheers |
Time averages are best done as the solver progresses. Have a look at the output options.
If you want to post-process time averages you will have to do that manually or by a script in CFD-Post. There are no functions built in to do it, to my knowledge. |
1 Attachment(s)
you need to use power syntax, see the example.
note:the following code could be executed in CFX POST command editor: ! @myTimeSteps = ("71","105","136"); # add your "solver steps" between brackets as they are listed in POST "Time Selector" ! $MyVariable = "Water.Superficial Velocity"; # put the variable of interset between quotes ! $MyPlane = "Plane zx"; # put the plane name here ! open(MyOutF,">C:/TimeAvgOut.csv") || die "Can't open file $!\n"; # this will create a Report file named "TimeAvgOut.csv" on root of C:\ drive ! $TStepsNo = @myTimeSteps; !print MyOutF "Time step , ",$MyVariable, "\n"; ! for ($i=0;$i<$TStepsNo;$i++){ > load timestep= $myTimeSteps[$i] ! $MyAvgVel = areaAve($MyVariable, $MyPlane,""); !print MyOutF $myTimeSteps[$i]," , ",$MyAvgVel, "\n"; !} ! close MyOutF; |
! $myTimeStepList = getValue("DATA READER", "Timestep List"); ! @myTimeSteps = split(/, /, $myTimeStepList); in case you want to do the calcs for all time steps, This will eliminate the need to extract the list of all time steps. |
