Problems at boundary conditions
Old   May 4, 2010, 20:19
Default Problems at boundary conditions
FM
Felipe Matos is on a distinguished road
I'm simulating a incompressible flow inside a cylindrical pipe with Reynold 100 (laminar). I'm setting:
- prescribed velocity (5cm/s) at inlet
- prescribed pressure (0 Pa) at outlet (reference pressure 1 atm)
- No slip wall at the cylindrical wall
Althought these boundaries ARE NOT variabels, when I plot the values on the nodes at each boundary they ARE NOT the same that I prescribed.
Example: the velocity at the wall are not zero. The values are around 10-3 cm/s but not zero as suposed.
The same thing is happening to the velocity at the inlet and to the pressure at the outlet.
Anyone knows what can this be?
Thanks
Felipe Matos is offline   Reply With Quote
Old   May 5, 2010, 04:05
Aero75 is on a distinguished road
Felipe,
Are you showing the values as conservative or hybrid on the boundaries? Conservative values will show the values based on the average in the control volumes. Hybrid values will overwrite the values at the elements nearest to the boundaries with the boundary values - this is what you probably want to do for your plots...
You can look it up in the CFD-Post manual. Whether you use conservative or hybrid values can be set when plotting in Post.
Regards,
Aero75
Aero75 is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 11:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
compressible boundary conditions vivian Main CFD Forum 8 April 24, 2006 06:23
Copying boundary conditions from model to model Lior FLUENT 3 September 23, 2004 16:10
