-   -   Beta value in High Resolution scheme (http://www.cfd-online.com/Forums/cfx/75937-beta-value-high-resolution-scheme.html)
gravis May 10, 2010 06:53
Hi all,
Is there any way to check what value \beta is limited to for different equations at the integration points, like a mean value for each control volume? I have not found any such variable in CFX-Pre that can be included under Output control.
Best regards,
Reine
ghorrocks May 10, 2010 07:57
When you activate the high-res differencing scheme then -beta variables are available in CFD-Post automatically.
gravis May 10, 2010 09:16
Glenn, thank you for your reply.
I am using High Resolution for Continuity, Momentum, Energy and Mass Fraction. In CFX-Post, I can only see the variable "Energy and Mass Fractions.Beta". If this is one of the variables you mention, how come there are not separate \beta values for Energy and Mass Fraction? (Also, why do I not see the corresponding variables for the remaining equations?)
/Reine
ghorrocks May 10, 2010 18:54
Yes, they are the variables I am talking about. I do not know why the energy equation and mass fraction equation uses the same beta.
gravis May 11, 2010 02:50
Thanks again.
Perhaps a bit off-topic for the CFX forum, but does anyone know if there are corresponding variabes available in Fluent (for the Standard Limiter in 2nd Order Upwind, with cell to face limiting), and the names of them?
