April 8, 2010, 22:49 |
Multi flow in two different domain
Arun
Rep Power: 16 |
I want to do simple concentric heat exchanger proplem so i created one fluid surface for inner flow and one solid surface for pipe thickness and another fluid surface for outer flow and meshed.
then import the mesh in cfx and created innerflow domain as fluid domain and given material as "Air at ideal gas" pipe thickness as solid domain and given material as "Stainless Steel" then i give outerflow as fluid domain and material as Water, what happened for innerflow also it taken as water, suggest me how to handle this problem i want to give two different fluid for two different domain |
April 9, 2010, 13:22 |
Rep Power: 21 |
In "Case Options > General" turn off "Constant Domain Physics".
April 9, 2010, 21:58 |
Same Problem
Arun
Rep Power: 16 |
May 11, 2010, 16:06 |
Rep Power: 16 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Porous domain in a flow field | rikio | CFX | 7 | August 25, 2009 22:39 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Negative pressures in the flow domain | mahut | FLUENT | 2 | September 27, 2007 05:07 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
