-   -   Immersed Solid no flow! (http://www.cfd-online.com/Forums/cfx/76026-immersed-solid-no-flow.html)
exocubedesign May 12, 2010 01:57
3 Attachment(s)
Hi folks,
I am a design engineer currently learning the ropes of CFX, I have a problem to solve of a moving gate valve, we are looking for cavitation issues behind the gate during high speed movement.
I have set up the transient simulation using an immersed solid domain for the moving gate and specifying a linear motion of the gate as a function of time for the duration of the test.
The fluid domain where the gate moves is of a fine mesh (finer than the solid) and contains interfaces with the other fluid domains.
When I run the simulation I can see the solid moving but do not get any fluid movement or pressure changes.
I have also run the tutorials without issue.
Any suggestions would be great.
cheers
exocubedesign May 16, 2010 23:54
Its been a few days and I thought I would bump this thread just in case anyone missed it over the weekend.
All help appreciated.
Thanks
ghorrocks May 17, 2010 06:54
Some comments:
* You should use units in your CEL expressions. "rotrpm" should be entered in units of rpm and then the conversion to rad/s is done internally.
* I think your problem may be in using "atstep" is Disp. It should be written in terms of simulations time "t"
exocubedesign May 25, 2010 01:57
Excellent advise my good man. I will pay closer attention to units from now on.
Getting some useful results now.
Many thanks
