May 11, 2010, 08:28 |
Turbulence metric
Enio Carpi
Rep Power: 16 |
Hi folks,
I'm simulating gas flow in small structures. I'll optimize the structure with turbulence as of one the output parameters. What would be the best metric to characterize turbulence? Thx for the help |
May 11, 2010, 18:28 |
Rep Power: 143 |
Depends on what you are interested in. Drag, mixing, turbulence intensity, boundary layer thickness etc etc could be parameters of interest depending on what is important to what you are doing.
May 12, 2010, 09:58 |
Enio Carpi
Rep Power: 16 |
I'm simulating a gas sensor, so I'm trying to optimize its dimensions by taking into account time to fill and pump out and how is the gas flow inside it, e.g. I may want certain degree of turbulence (if it helps the reaction inside) provided that pumping down is not (much) affected.
May 12, 2010, 18:47 |
Rep Power: 143 |
So it sounds like drag and mixing are the key parameters for you.
May 13, 2010, 07:46 |
Enio Carpi
Rep Power: 16 |
I'll try them. thx a lot
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
