-   -   trouble in applied BC (http://www.cfd-online.com/Forums/cfx/76132-trouble-applied-bc.html)
m.qafari May 15, 2010 03:01
I’m going to model viscous flow passes through porous duct in CFX or Fluent software. This process is time dependent and there are two immiscible fluids (Air and resin).
At first, there is air in duct. A vacuum pump in deferent produces vacuum at the duct’s outlet and exhausts air and air is replaced by resin.
What types of boundary condition are suitable for this simulation in CFX or Fluent software? Can I apply pressure inlet as intake boundary condition, while pressure outlet is applied as outlet vent?
I tried to model a viscous flow by “pressure inlet” and “pressure outlet” in CFX but there was a trouble and CFX announced “floating point exception” and solve was terminated with error so soon. CFX manual offers that applicants should use “velocity inlet”! But I don’t know anything about velocity of fluids in domain.
What can I do?
I would be very grateful for any advice.
Best regards.
ghorrocks May 15, 2010 07:05
You should be able to use a pressure inlet for this application.
The floating point exception just means the solver has diverged big-time. You just need to improve numerical stability - try smaller time steps, double precision solver, improving mesh quality etc. Also be careful with the porous region, that can cause convergence difficulties.
