Home > Forums > CFX
Particle Tracking
Old   May 17, 2010, 06:20
Default Particle Tracking
Claudia is on a distinguished road
there are two possibilties for particle tracking in CFD: simultaneous and gradual. Which kind of tracking is implemented in CFX for steady state simulations?
Thanks in advance
Claudia
Claudia is offline   Reply With Quote
Old   May 17, 2010, 06:42
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I have no idea what simultaneous and gradual means. In CFX, for steady state simulations you can have one-way coupled particles (where the particles do not affect the flow field) and two-way coupled particles (where the particle affects the flow field).
Old   May 17, 2010, 06:59
Sorry, I think the question was not clear.
Just try again:
If I have a lagrangian particle tracking, I have a calculation of the particle tracks.
Does CFX calculate first one complete track from start to end and then the next track from start to end and so on?
or:
takes CFX every particle at the same time, moves all particel a small timestep, and calculate them again?
Was it more clear?
Thanks,
Claudia
Old   May 17, 2010, 08:07
I don't know. Why does it matter? In a steady state simulation run to convergence the answer will be the same.
Old   May 17, 2010, 08:10
This is a part of the simulation theory in my PhD. But you are right, it should have no influence on the results :-)
Old   May 17, 2010, 18:50
The more important question is how the particle tracks are coupled back to the flow in the case of two-way coupling. In this case the flow is solved, then the particle tracks are solved based on the flow field, then the flow is re-computed based on the coupling with the particle tracks.
Old   May 18, 2010, 02:42
Glenn, you are completely right, it was information only :-).
The Way of coupling is two-way and this is the right choice for this problem.
Greets, Claudia
Thread Tools
Trackbacks are On
particle tracking Wenqing Zhang CFX 15 August 3, 2013 06:02
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle tracking - Domain interface / FrozenRotor mohanrao CFX 4 January 23, 2008 04:39
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 19:26
