-   -   solving algorithm in CFX (http://www.cfd-online.com/Forums/cfx/76571-solving-algorithm-cfx.html)
feizaghaee May 29, 2010 08:01
does anybody know which algorithm cfx uses to solve a problem?(simple, simpelc, piso ...)
and how can i use QUICK scheme?
ghorrocks May 29, 2010 17:55
It is all explained in the documentation. It uses a coupled solver. It does not use the uncoupled methods you describe.
As for QUICK, you need to set that up with CEL.
feizaghaee May 30, 2010 02:45
thanks a lot my friend
cfdman May 31, 2010 01:36
Hello Glen,
Which solver algorithms, schemes available in CFX? Could you give some details about this?
Thanks
ghorrocks May 31, 2010 02:02
DOCUMENTATION. Read it. If you want more details followup the references in the doco.
Mina_Shahi January 13, 2012 12:49
1 Attachment(s)
Hi Glenn
I am confused i read CFX theory manual but i didn't get the point and the references are too old and it is not available for me.
I also read your advise in other pages in this Froum, what i understood is that CFX doesn't use SIMPLE- SIMPLEC- SIMPLER or PISO- but it does pressure velocity coupling, it uses Rhie Chow for interpolating. Is it true???
i found this document when i was searching on the google Attachment 10838 if you go to page D-19 you can see that it is talking about SIMPLEC which made me even more confused, can you please take a look at this document and let me know what you think? :cool:
Thank you in advance
Far January 14, 2012 00:31
Yes, It is true.
ghorrocks January 14, 2012 06:59
The document you found is using CFX4. This was the previous CFD code, and was superseded by CFX5. CFX5 is a coupled solver and does not use SIMPLE (or its variants). All versions of CFX after 5 use the coupled solver.
Mina_Shahi January 16, 2012 06:32
Thank you for replying me, because this document made me so confused,
