How to access a parameter from a previous timestep
Old   June 13, 2010, 04:31
Default How to access a parameter from a previous timestep
Ridley is on a distinguished road
Hi, I have a problem with a CEL-expression, where the density from the previous timestep (transient simulation) is needed for the calculation. Is it possible to access the density from this previous timestep just by using CEL-Code?
Thanks a lot!
Ridley is offline   Reply With Quote
Old   June 13, 2010, 10:29
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
hi, you have to use density(current time step -1)@somewhere. search for the syntax code of the current time step (for example, current iteration number is "citern"). i don't know surely, but it should work.
Attesz is offline   Reply With Quote
Old   June 14, 2010, 18:40
Sorry, but the answer is no. It is not possible. This is the biggest failing in CFX CEL. You may be able to use an additional variable and make use of the fact the CEL is updated at the start of a time step and additional variables at the end - but I have not confirmed this works.
Old   June 15, 2010, 03:06
Attesz's Avatar
Attesz
I used it by adjusting the RPM's, outlet pressures etc. But as I see, for the flow parameters it is not suitable. It's really a big fail...
Old   June 15, 2010, 06:55
What is an RPM?
Old   June 15, 2010, 06:56
Attesz's Avatar
Attesz
Sorry, Revolutions Per Minute
OpenFOAM - Quick way to delete previous calculation & HowTo get access to variables kriz OpenFOAM 12 March 6, 2023 03:20
Resolving from a previous timestep juho OpenFOAM Running, Solving & CFD 3 June 2, 2010 15:50
Access parameter value from within DEFINE_PROFILE ??? TDi Fluent UDF and Scheme Programming 3 May 17, 2010 15:10
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Accessing Variables from Previous Timestep Vinayak Barve FLUENT 1 March 10, 2004 07:40
