Home > Forums > CFX
about function calculator
Old   June 2, 2010, 09:46
Default about function calculator
extinguisher is on a distinguished road
The AoA is 12 degree,velocity is 10m/s
the X component force of the wing finally increases the Lift force and decreases the Drag force
extinguisher is offline   Reply With Quote
Old   June 2, 2010, 18:35
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
And your question is......
Old   June 4, 2010, 02:01
the result (-2.08692N)of the X component was right or wrong?
Old   June 4, 2010, 08:21
Are you asking if the force in the X direction is -2N - sounds wrong to me as the drag should be in the + direction, but I have no idea what you are modelling so cannot be sure.
Old   June 6, 2010, 03:46
I simulated a three-dimensional flow around the wing, angle of attack from 0 degrees to completely stall.
Old   June 6, 2010, 06:23
If you are running steady state then you have not run it to convergence. If you are running transient and you are near stall it is quite possible the airfoil will have short periods of negative drag. Averaged over time the drag will be positive.
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
