-   -   ERROR #001100279 has occurred in subroutine ErrAction. REDHDR:locating dataset failed (http://www.cfd-online.com/Forums/cfx/76785-error-001100279-has-occurred-subroutine-erraction-redhdr-locating-dataset-failed.html)
Andy QUB June 4, 2010 08:25
Hi all,
I'm trying to run a simulation but it seems to be terminating with errors with the above message. The output file doesn't seem to give any other info and I was just wondering if anyone has had a similar experience or know what may be causing it.
Many thanks,
Andy
Clasen August 2, 2011 09:17
Hi Andy
I found this error:
REDHDR: locating dataset failed: what=S/KCsIp where=ZN8/FS1
Stopped in routine REDHDR
I also found an answer that helped to achieve in a possible cause.
This happened when I created a .cfx and .def file from a .res file. Some bug make the program miss the mesh reference.
To fix, I recreated all my case from the original .cfx file.
You can also try to recreate it from the mesh file.
I hope this helps you
gstardeluxe July 15, 2014 16:11
Thx Clasen, this helped :)
