-   -   Cannot start CFX 12.1 on WinXP Pro (http://www.cfd-online.com/Forums/cfx/76793-cannot-start-cfx-12-1-winxp-pro.html)
Udio_NT June 4, 2010 09:48
Hi everyone,
I tried to install ansys12.1 on WindowsXP Professional. I can start the Workbench, Fluent, ICEM, but CFX doesn't work, it appears only the icon for few seconds and no windows open.
If I try to start it from the command prompt the error message is:
Can't locate loadable object for module Win32::Job in @INC (@INC contains: C:\Pr
ogrammi\ANSYS Inc\v121\CFX\bin\/perllib C:/Programmi/ANSYS Inc/v121/CFX/tools/perl-5.9.5/lib/MSWin32-x86-perlio C:/Programmi/ANSYS Inc/v121/CFX/tools/perl-5.9.5/lib C:/Programmi/ANSYS Inc/v121/CFX/tools/perl-5.9.5/site/lib/MSWin32-x86-perlio C:/Programmi/ANSYS Inc/v121/CFX/tools/perl-5.9.5/site/lib .) at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Win32/Commands.pm line 71
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Win32/Commands.pm line 71.
BEGIN failed--compilation aborted at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Win32/Commands.pm line 71.
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Commands/Win32.pm line 24.
BEGIN failed--compilation aborted at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Commands/Win32.pm line 24.
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/Commands.pm line 50.
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/System.pm line 26.
BEGIN failed--compilation aborted at C:\Programmi\ANSYS Inc\v121\CFX\bin\/perllib/CFX5/System.pm line 26.
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\perllib\cfx5launch.pl line 90.
BEGIN failed--compilation aborted at C:\Programmi\ANSYS Inc\v121\CFX\bin\perllib\cfx5launch.pl line 90.
Compilation failed in require at C:\Programmi\ANSYS Inc\v121\CFX\bin\perllib\cfx5.pl line 58.
Thank you.
mhettegger June 18, 2010 06:30
hi!
had exactly the same problem on one of my pcs. tried to install ansys four times - got the same error after each installation. found a solution after several days trial and error. i compared the content of the folder
c:\program files\ansys inc
with a pc where cfx works well by simply using the command "dir /b /s > dir.txt". obviously the installation routine of ansys forgets to copy some files (no mather if you install as user administrator or as a user with administrator rights)
i found a difference in the folders
C:\Program Files\ANSYS Inc\v121\CFX\config
and
C:\Program Files\ANSYS Inc\v121\CFX\tools\perl-5.9.5\site\lib\MSWin32-x64-perlio
i took these folders from the working installation and copied them to the pc of the failed installation. maybe this worked because the two pcs have the same operating system (winxp pro 64 bit) and similar types of cpu (intel dual core).
i hope this can help to solve your problem.
have a nice day,
Martin
Udio_NT June 18, 2010 07:10
Hello!
Thank you very much for helping me.
Your solution could work also in my case!
At the moment I reinstalled Ansys 12.0 and CFX works. If we decide to install again Ansys 12.1 on the pc with windows xp pro, I will try your solution!
Thank you again!
Have a nice day, you too.
Claudio
