fan vs experimental data
Old   June 1, 2010, 07:03
Default fan vs experimental data
ijk
ijk is on a distinguished road
Hi all,
I am trying to generate a fan curve from experimental data using CFX. I have found that it does not converge steady state so I run it transient.
The fan is an axial fan but I am running in the stalled mixed flow region. I have found that my course mesh using wall functions (yplus100 on blade) is about 15% low in mass flow for a given loading. The steady state is way off.
I have yplus 30 and 1 cases running but they take forever. Perhaps a PHD using CFD was a bad idea.
Are these normal results for CFX? I have some friends who have done similar work with Star CD and they have got transient results within 5%.
I am not 100% that the experimental results are correct as the airflow was measured using anemometers and not a proper venturi setup.
Any advice anyone could give would be much appreciated.
Thanks
ijk is offline   Reply With Quote
Old   June 1, 2010, 18:46
Getting accurate results in the stalled region is difficult, so you have a difficult project. That means you can expect long run times.
It also means you may not be able to use a turbulence model to get good results, you may be forced to use DES/SAS to get improvement - but that will just increase your run time more.
There are no simple answers in CFD, especially with difficult work like stall modelling.
I would be very surprised that the difference between your results and Star-CD is purely the solver. I would suggest either the user knew what he was doing better or was lucky.
Old   June 7, 2010, 04:42
ijk
Thanks Glenn
Tecplot. add experimental data into a mesh Alejandro FLUENT 0 December 10, 2008 07:08
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Looking for the experimental data COLOPOLO Main CFD Forum 2 January 28, 2004 23:38
Simulated data vs. experimental data moiami FLUENT 0 December 19, 2002 01:03
Experimental data for fence at low Reynolds number Kim Bindesboll Andersen Main CFD Forum 1 September 26, 2002 13:54
