June 9, 2010, 19:36 |
[CFXv11]fluid temperature distr problem
Rep Power: 16 |
Dear all,
I'm having some difficulty understanding the reason why there's a kind of huge temperature rise at the inlet side of the fluid model. Referring to the attached picture, the inlet is on the right side of the helical channel. Encircled are regions where you find huge temperature rise from cold to hot fluid. I have a heat source in the inner surface which is not shown. is there a reason why there's a huge temperature rise at the encircled region please? i would expect to see gradual increase in temperature instead. Hope to hear any comments/suggestions you may have.
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
June 10, 2010, 08:08 |
Rep Power: 143 |
Have a look at the streamlines behind it. I bet there is a jet of hot fluid just behind it which is keeping it hot, or something like that.
temperature gradient problem in udf | Souviktor | Fluent UDF and Scheme Programming | 6 | March 10, 2019 05:48 |
PorousMedia Problem with Temperature Distribution | pawan | OpenFOAM Running, Solving & CFD | 2 | August 2, 2015 23:08 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
HELP!: swimming pool flow problem | Tee | FLUENT | 1 | September 8, 2005 08:29 |
Static temperature | David | FLUENT | 2 | April 1, 2005 10:57 |
