-   -   cylinder and piston (http://www.cfd-online.com/Forums/cfx/77006-cylinder-piston.html)
m.shams June 10, 2010 07:16
cylinder and piston
2 Attachment(s)
Hi every one
Excuse me if my English is not good.
I am beginner in cfx. i simulated cylinder and piston. figure below indicates the geometry and meshes. For simulating piston I used mesh deformation feature and analyze type is transient. but when solving error below occured.
If possible, please guide me.
Thanks a lot
Error:
Fluid Flow_003 has terminated with errors.
Run concluded at: Wed Nov 10 15:25:42 2010
Results are in
C:\piston- 1 domain\piston_files\dp0\CFX\CFX\Fluid Flow_003.res
the *.out file of solution attached to this post
ghorrocks June 10, 2010 08:13
You have defined the piston motion as a constant - 2[m]. This means the mesh will jump to this position in the first time step and stop there. This is wrong, you have to write the displacement as a function of time, maybe a sin() function or something so the piston can move gradually as a function of time from the starting location to the finish location.
m.shams June 10, 2010 15:21
my problem solved with your guid
thanks a lot for your reply.
