Vacuum pumping
Old   May 6, 2010, 08:55
Default Vacuum pumping
Enio Carpi
MrFEA is on a distinguished road
Hi Folks
I'm new to CFX. I'mtrying to simulate pressue inside a chamber connected to a vacuum pump. I have one intake with as wall (valve closed) and the other as outlet with mass flow. Inside is Air (ideal gas). Initial conditions of pressure is zero (relative to ambient 760 Torr).
The problem is to write boundary conditions of the outlet as the flow is a function of the pressure. I'm using a very simple equation using volumeAve(Pressure)@chamber X constant as test but flow is zero and the pressure doesn't drop. With a constant out flow it works fine.
Any ideas? Thx
MrFEA is offline   Reply With Quote
Old   June 2, 2010, 05:42
FabOr is on a distinguished road
have you solved your problem?
FabOr is offline   Reply With Quote
Old   June 2, 2010, 07:11
Enio Carpi
Originally Posted by FabOr View Post
Yep, thx. Now it works fine. Waiting for benchmarking against experimental results.
Old   June 3, 2010, 08:19
Can you send me your file?
I have the same problem.
thx.
my e-mail: bguser@gmx.de
Old   June 7, 2010, 15:14
Enio Carpi
thx.
sorry, can't do. Hope the following will help:
1. inlet = wall
2. outlet with mass flow, as per your vacuum pump (I used mass flow as function of Pressure) - air ideal gas
3. transient simulation
4. monitor pressure (I used volume average) per simulation time. When you have enough points kill it, or let it run till end and export monitor.
Let me know how it goes. Rgds
Old   June 11, 2010, 06:17
i used a fixed value for the velocity at the outlet, but the pressure is increasing. i donīt know really why this happen...
here are my boundary conditions
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
outlet
type fixedValue;
value uniform (0 0 5);
chamber
type fixedValue;
value uniform (0 0 0);
pipe
type fixedValue;
p:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 100000;
boundaryField
outlet
type zeroGradient;
chamber
type zeroGradient;
pipe
type zeroGradient;
Maybe someone can give me a hint how to solve this problem.
thx
modeling vacuum condition Mike Siemens 1 May 3, 2016 03:10
Vacuum with two-phase flow Ahmed Khattab FLUENT 2 August 8, 2010 11:38
Radiation in vacuum nitin CFX 0 July 6, 2009 01:49
how to create vacuum in fluent shajib56 Main CFD Forum 0 April 17, 2009 12:11
oxygen lance simualtion in vacuum rensb FLUENT 0 July 17, 2006 02:14
