June 13, 2010, 10:00 |
[CFXv11]importing CFX convection into WB
Rep Power: 16 |
Dear all,
i'm encountering another problem while importing CFX convection into WBv11. please see attached picture. Figure 1: areas in the cooling channel on the housing that is interfacing with fluid. Notice the areas of the coolant ports are selected Figure 2: areas defined as cooling channel on housing interfacing with fluid in CFX-Post. Note that, the default interface DID NOT select the coolant port areas. however, the simulation in WB completed smoothly. i would expect WB to pop out a message claiming that importing will not be possible, because the interface definitions are not entirely correct and transfering data between the nodes will not be possible. but why has WB completed the simulation even though the interfaces are not matching? Any thoughts will be helpful. Because, now when i re-do another calculation with a different fluid flowrate, WB is complaining that transfering data between nodes is not successful. Please help.
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
June 14, 2010, 18:37 |
Rep Power: 143 |
If faces do not match then the GGI assumes they are not in contact. Then it applies slip/adiabatic walls on those faces. You can make them no slip/heat transfer walls in the options.
You usually have to fix the default selection of interfaces as the default guess is wrong. It is tedious but necessary. |
natural convection in ANSYS CFX 10 | cryo man | ANSYS | 0 | June 9, 2009 07:53 |
natural convection problem in cfx | NVSD BABU | CFX | 7 | November 13, 2008 10:56 |
Natural convection problem in CFX 11 | Willy | CFX | 2 | May 23, 2008 23:12 |
Thermocapillary/Marangoni Convection in CFX | Seamus | CFX | 6 | May 30, 2007 20:38 |
CFX to model convection cells | FER | CFX | 4 | December 13, 2006 00:57 |
