Problem with Grid convergence study
Old   June 12, 2010, 19:11
Post Problem with Grid convergence study
dialolema is on a distinguished road
I am simulating 5 degree slice of a cylinderical reactor having two inlets at the top face of the slice, one for solid fuel & one for oxygen inlet, and an outlet at the bottom face of the slice. This model has two symmetry face and the rest are walls.
I have created three meshes using CFX-mesh for my grid convergence study. I have used global mesh scaling factor, point control and infilation to generate three meshes for my study. However, the solutions from the three meshes are not consistent meaning, the solutions are not in increasing or decreasing order. I have tried quite a lot of time and problem persist. Is there any one who colud give me a peaces of advice.
regards,
Dialo
dialolema is offline   Reply With Quote
Old   June 14, 2010, 07:12
Max Efficiency is on a distinguished road
The slice of 5 degree could be too small. Increase this value and simulate 15 degree or even more of the reactor. Maybe you need a slice of up to 45 degree. Even if a process has a symmetry you cannot make the slice infinite small. The necessary sice of the slice differs from case to case.
Max Efficiency is offline   Reply With Quote
Grid size, convergence issues franzdrs Main CFD Forum 3 June 18, 2009 07:57
convergence for higher grid points sandip Phoenics 3 April 15, 2009 13:25
Continuity eq convergence problem carno FLUENT 4 February 8, 2008 04:04
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
