A Strange Problem in making Parallel (Ansys/CFX 12)
Old   June 22, 2010, 16:24
Default A Strange Problem in making Parallel (Ansys/CFX 12)
Ali Sarami
a.sarami is on a distinguished road
I have a very strange problem with CFX 12 solver, when I want to use HP MPI local parallel mode of solving.
sometimes all the things are OK and the solver begin to solve. but most of the times after partitionting, when the solver just want to start, suddenly cpu rates fail to zero and nothing happens. no solving, no error, no cpu rate
| Partitioning CPU-Time Requirements |
- Preparations 1.375E+00 seconds
- Low-level mesh partitioning 2.969E-01 seconds
- Global partitioning information 4.688E-02 seconds
- Element and face partitioning information 7.813E-02 seconds
- Vertex partitioning information 1.563E-02 seconds
- Partitioning information compression 0.000E+00 seconds
- Summed CPU-time for mesh partitioning 1.844E+00 seconds
| Job Information |
Host computer: ALI
Job finished: Tue Jun 22 23:36:07 2010
Total CPU time: 2.906E+00 seconds
or: ( 0: 0: 0: 2.906 )
( Days: Hours: Minutes: Seconds )
Total wall clock time: 5.000E+00 seconds
or: ( 0: 0: 0: 5.000 )
| Solver |
nothing happens after it!!!!!!!
!!!!!! but one thing very strange is that when my computer is connected to internet all the thing is ok and parallel solving proceeds, but when I disconnect it suddenly an error apears and MPI loose its connection!!!!!
why??
a thing to be noted is the fact that in all the above happenings (sometimes solving without error, sometimes errors ,....) I have used the same *.def file!
Please help me with this problem as soon as possible
Thank you
a.sarami is offline   Reply With Quote
Old   June 22, 2010, 19:39
This can be caused by a problem in the parallel setup. Do other parallel modes work?
ghorrocks is online now   Reply With Quote
Old   June 23, 2010, 00:53
Default Rep
Ali Sarami
No, unfortunately. none of them works,
for distributed ones the solver is terminated with an error. for local ones the above-mentioned problem happens
Old   June 23, 2010, 00:59
Ali Sarami
but one thing strange is that, sometimes (rarely without any regularity) the parallel solving proceeds while U have used the same parallel settings as the ones that stops!!!
Old   June 23, 2010, 06:06
Daniel Paukner
Pocket is on a distinguished road
This could be a MPI network error.
I am not too sure about this, so don't nail me down on it, but i do remember that another software i used a few years ago (Folding@Home) had a problem with disconnections in the MPI coupling, when the wireless was trying to reconnect to a network. It was some sort of error in the MPI implementation used on Windows machines.
Do you have a LAN connection active or is the internet protocol the only network protocol activated? It might be that it is just a networking problem.
Also, if you specify more solving partitions then you have CPU's available, it will start to run, but the cpu load drops to zero and nothing happens.
Pocket is offline   Reply With Quote
Old   June 23, 2010, 08:38
Ali Sarami
No, I have no LAN,
My CPU has 8 cores and I have just tried to make 2 or 4 of them parallel.
Old   June 25, 2010, 08:01
Ali Sarami
if anyone can help me, I would be the most grateful. I am urgently need your help.
Old   June 26, 2010, 07:41
Check that you have licenses available, your network is reliable and your hard drive is not full and you have sufficient memory.
Old   June 28, 2010, 03:42
Jurij Sodja
sodjaj is on a distinguished road
Did you check the size ofthe mesh. I had similar problems when the mesh used was to big to fit in the computer's RAM.
regards,
Jurij
sodjaj is offline   Reply With Quote
Old   July 5, 2010, 15:04
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
hi ali as sodjaj said it can be result of excess number of mesh check it out.
feizaghaee is offline   Reply With Quote
Old   July 9, 2010, 01:34
Dick Chase
Showman is on a distinguished road
I have the same problem using Win7Pro x64. The solver starts if I choose serial run mode only. The PC has no connection to any network. The firewall is off. ICEM CFD works fine in parallel.
Is there any solution? May be should I install any additional software?
Showman is offline   Reply With Quote
Old   July 9, 2010, 02:44
Dick Chase
I resolved the issue. The problem is that MPI needs connected LAN with IP address. I just looped one LAN to another LAN on the PC. Then I disabled the LAN and wrote IP number to another LAN. That's it, it works.
Old   July 14, 2010, 22:45
Default responding to
  #13
labib
nuimlabib is on a distinguished road
i also got the problem for paralel operation
nuimlabib is offline   Reply With Quote
Old   October 7, 2010, 01:33
ali
alinik is on a distinguished road
Hi showman
I am having the exact same problem, I couldn't get what you have done. could you please explain me in details?
Thanks
alinik is offline   Reply With Quote
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
parallel problem rui Siemens 2 July 31, 2007 13:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
PROBLEM IN PARALLEL PROGRAMMING WITH MPI Niavarani Main CFD Forum 1 April 20, 2004 06:51
