User Fortran - Alter variables in runtime
Old   July 5, 2010, 09:42
Default User Fortran - Alter variables in runtime
Peter
ellevset is on a distinguished road
Hi
Is it is possible to use User fortran to change simulation variables. For example applying a step function to the Soot Mass Fraction of the Magnusson Soot model.
Peter
ellevset is offline   Reply With Quote
Old   July 5, 2010, 20:01
Yes, it should be possible. Sounds like a bad idea as the numerics will be unstable. Why do you want to apply a step function to the mass fraction?
Old   July 6, 2010, 04:10
Peter
I agree, it does sound like a bad ideas, but I have been experiencing some problems with the soot model. The entire domain is filled with a small amount of soot, of the order 1E-05. Even far away from the combustion.
I thought perhaps adding a filter would solve this problem.
Another question on User Fortran. When you create subprocesses are they automatically calculated of every cell, or do you have to specify where the calculation is done?
Old   July 6, 2010, 19:37
In this case your suggestion sounds like a really bad idea. You should check the simulation setup, have a look at the tutorials or ask CFX support for a demo file. I can't see how your suggestion will help.
Read the documentation on user fortran about how it works. There are two approaches - and I will let the documentation explain what they are.
runtime, soot model, user fortran
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
User Fortran and interior node information John CFX 0 August 26, 2008 23:24
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 02:31
Best Code for User Fortran worth Main CFD Forum 4 November 14, 2003 11:21
