ANSYS CFX: Produce swirling flow using cylindrical components
Old   July 6, 2010, 09:49
Default ANSYS CFX: Produce swirling flow using cylindrical components
Neil Duffy
neilduffy1024 is on a distinguished road
Hi, I want to mimic swirling flow into a furnace using cylindrical components in the boundary conditions. I want to specify a mass flowrate followed by the flow direction. The axis of rotation will be specified as two points.
There is no decription in the user guides how the theta component is used. When selecting the cylindrical velocity components the units are for linear velocity, ie m/s etc, which obviously depends on the distance from the axis of rotation, yet there is no description in the user guides of how CFX accounts for this. Can the theta component be specified in terms of an angular velocity, ie radians/s, or as a linear velocity dependent on the distance from the axis of rotation, ie a velocity profile, perhaps using a CEL expression? If so, is there a simpler/more efficient method of describing this than through user Fortran?
Any help would be greatly appreciated.
Thanks,
Neil
neilduffy1024 is offline   Reply With Quote
Old   June 4, 2013, 17:18
Michal
magnusDux85 is on a distinguished road
I have the same question. I want to mimic swirling flow in the injector.
magnusDux85 is offline   Reply With Quote
Old   June 5, 2013, 06:02
Not sure if you can specify this using a rotating boundary coordinate system. Have a look and try it.
But it is easy to set this up as CEL expressions. A bit of maths to work out, that's all.
ghorrocks is online now   Reply With Quote
Old   August 7, 2013, 07:52
Michal
Have you ever tried, could you give us some details?
Old   August 7, 2013, 08:00
No, never needed to do it so I have never done it.
But my second point is that it is easy to write it in the global coordinates, the transformation from cylindrical to global cartesian coords is pretty simple. So if it cannot be done in cylindrical coords then do it in global coords.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
ANSYS CFX Tutorial Rashid CFX 25 December 20, 2012 01:22
ANSYS Multi-physics and CFX coupling error anujit CFX 3 June 21, 2009 18:39
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 13:31
