Initial condition
Old   July 14, 2010, 23:29
Default Initial condition
John
jszl is on a distinguished road
Dear All,
I want to know how to put only the final data for continuing the program instead of using the previous result file.
I kept using the result file but the longer the time taken to conclude, the more the number of iteration.
Hope someone can help me.
Thanks a lot
jszl is offline   Reply With Quote
Old   July 15, 2010, 08:36
Tommy
TommySean is on a distinguished road
Originally Posted by jszl View Post
Dear All,
Thanks a lot
Do you mean to restart the simulation with a previous result as initial flow field, and you want the iteration history to also restart from 0?
In CFX 11, you should set the solve to start with an option of "interpolation". This will make the iteration history curve start from step 0 again. Otherwise the solver will use mesh and boundary settings from the old result file.
In CFX 12, there's an option of "continue iteration hisory" when you specify the initialization result file. And you can specify which mesh will be used, the solver input(def) or the result file.
TommySean is offline   Reply With Quote
Old   July 16, 2010, 10:16
John
Thanks a lot Tom,
I want to do so.
Now I am trying it.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
