Flash Process / Problem with thermal phase change model
Old   July 21, 2010, 07:57
Default Flash Process / Problem with thermal phase change model
Ridley is on a distinguished road
Hey guys,
I´m simulating a flash process where hot saturated water (180°C) is injected into a cyclone (which is filled with hot saturated steam with 120°C) and partially evaporates as the pressure in the cyclone is about 2 bar. Unfortunately I have not been able to model the fast cooling down of the water so far by using the thermal phase change model (in the real process water has about 110°C at the end). Even though pressure (at the outlet) drops constantly, water temperature remains well above the saturation temperature and evaporation rate is very low (say about 1%, whereas in the real process about 20% of the water evaporates).
I´m using Euler/Euler-Model with Water as continuous phase and Steam Bubbles as dispersed phase and inhomogeneous model for multiphase and turbulence. The system has an inlet where the hot water is injected and an outlet where the vapour can escape. I´ve tried with Steam and Water as continous phases (evaporation rate was even lower) as well as changing heat transfer coefficients but it didn´t help. Perhaps it would be more appropriate to use cavitation for phase change but its very difficult to converge and results weren´t very promising so far.
Maybe someone already had a similar problem and could give me a hint? Thanks a lot!
Ridley is offline   Reply With Quote
Two Phase Flow Problem miner15kick CFX 5 October 28, 2010 18:03
Best CFD software to model phase change ana Main CFD Forum 5 June 10, 2009 07:43
phase change process shen qingqing FLUENT 0 September 7, 2008 09:29
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 11:41
