CFX_Batch File
Hi all,
I want to run CFX in batch mode. Could you pls tell me the whole path and sequence. like CFX-Pre...CFX-Solver----CFD-Post I tried like: C:\Users\sanaz\Desktop>"C:\Program Files\ANSYS Inc\v121\CFX\bin\cfx5pre"-batch ROTOR.pre But it is not working. Is there anyone know how to get it ? Thanks in advance!!! |
Use a command line started in the CFX launcher. Then the path will be correctly defined.
You need a space before -batch. |
Yes tried with cfx5sole and afterthat same path it working now. But my mesh will be chnage every time, I buil script in ICEM CFD. So what wil be the exact path from this mesh file to upto the solution.I wanter to calculate efficiency i introduce ccl file for that. How can i get that eficiency thoruh this path. Kindly let me know. Best Regards, Quote:
Unfortunately, I am not familiar with this. However, some of the folks in the following thread may be helpful
http://www.cfd-online.com/Forums/cfx/73105-batch-cfx-12-windows-xp.html Good luck! |
CFX support has some example files of linking a CFX solution to ICEM meshing dynamically. Talk to CFX support.
