icem script
Old   November 26, 2008, 03:52
Default icem script
prad
Hello! I'd posted this some time ago. I've got 3 icem .rpl scripts to run my simple geometry creation, meshing and conversion to .cfx5 format. All 3 scripts run individually at the DOS prompt as well as in icem replay mode. If I load the commands into a .bat file only the first command is run. The window then closes. Has anyone encountered this before? Suggestions are requested and are welcome. Prad The commands are: echo ICEM Tetin "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_tin.rpl echo ICEM Mesh "C:\Prog..........icemcfd\win\bin\icemcfd.bat" -batch -script icemcfd_hex.rpl echo ICEM cfx5convertion "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_con.rpl
Old   November 26, 2008, 05:36
Default Re: icem script
Rogerio Fernandes Brito
Can u show us an example of this icem script?
Make the upload in http://rapidshare.de/
Thanks!
Old   November 26, 2008, 07:19
prad
There's really nothing more to it: the tin is a 2d square. The 2d planar blocking, edge definition and meshing is defined in the icemcfd_hex.rpl Conversion to .cfx5 format is in the last .rpl. Put all three in a test.bat and double click, only one line runs.
Old   November 26, 2008, 07:55
Is this the code?
Old   December 16, 2008, 14:32
JS
I'm not sure the connection between the scripts. Each script includes an 'exit' command at the end of line?
Old   July 23, 2010, 16:30
Saima
Saima is an unknown quantity at this point
Do u know wat is batch command for CFX.
my Mesh is in ICEM and every time it will be change , so i want to gice CFX commands starting with msh file. Do u know the way? If yes pls let me know.
Regards,
Originally Posted by prad
;91018
Saima is offline   Reply With Quote
[ANSYS Meshing] Problem with Icem Script Krish ANSYS Meshing & Geometry 0 October 18, 2011 12:10
[ICEM] SCRIPT File in ICEM CFD Saima ANSYS Meshing & Geometry 0 July 15, 2010 14:27
Using script file in ICEM CFD Debabrata Mahapatra CFX 1 October 22, 2007 17:45
script file to convert meshes from ICEM 4 to 10 Seb CFX 0 July 6, 2006 10:40
Icem script error in Workbench environment mech80 CFX 11 September 19, 2005 18:13
