NASA Rotor 67 (2D) in CFX
Old   July 20, 2010, 11:22
Default NASA Rotor 67 (2D) in CFX
Saima
Saima is an unknown quantity at this point
Hi All,
I am doing NASA rotor 67 profile(2D) in CFX, when i import 2D meshing in CFX it automatically convert in 3D by taking unit width.. I picked section number-6 which is on staking angle 50 deg.
I know all data of that section. Like inlet out static and total pressure and temperatutre with absolute, relative and meridonal velocities. I have rotaional speed of blade.
1. I put inlet: Total temp and Total Pressure
Outlet: static pressure and static temp
2. I put inlet: Mass flow rate
3. I put inlet: Total temp and Total Pressure
Outlet: Mass flow rate
In all cases i took airfoil as a rotating with blade speed around 16,000.0 RPM.
But i havent got good result. All the time my inlet and outlet total temperature is same in all three cases. Why is that?
I took shroud and hub as a symmetry condition.
I want to calculate total efficiency which is function of inlet and outlet total pressure and temperature.
Kindly suggest me what shud i do.
Thank you and Regards,
Saima is offline   Reply With Quote
Old   July 20, 2010, 23:46
If they all define the same flow you will get the same flow. Total pressure/temperature approximately equals the static pressure/temperature when the velocity is small so it is easy to see why they can be the same. If your defined pressure difference is the same in case 1 as you get in case 2 or 3 then you are just defining the same flow a different method, so will get the same answer.
Old   July 29, 2010, 14:50
Saima
In real data T01 = 288K
P01 = 101352 Pa
Ps2 = 127523.60 Pa
and T02 = 340
P02 = 164757.0 Pa
but i am getting T02 = 288.17K
P02 = 113526.23 Pa
I choose 1 with total pressure and tem at inlet and static pressure outlet.
I fixed whole domain stationary and select my blade rotating with speed 16046 RPM.If i take domain rotation it doesn't run and gave error right away.
I chose periodic conditions but periodicity translation because if i took rotational it doesn't run and gave error right away.
CFX automatically covert 2D air foil in 3D but with small thicknes. So i took top and bottom as Hub and shroud but with symmetry boundry conditions. I tried Wall but i was not run.
I choose Material :Air ideal Gas.
Heat Transfer Model : Total Energy
Turbulance Model: SST
Kindly suggest me y is that?
Thank you
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
