Blood flow through pipe
1 Attachment(s)
I am trying to simulate simple problem like fluid flow through pipe of 8cm(artery).
my input velocity is 0.12m/s .outlet relative pressure is 0 Pa. Reference pressure is 1 atm . if analysis has done in ansys CFX what is the pressure at the inlet ,pressure at the outlet and inside the pipe through out ? my analysis is steady state analysis . according to the theory if the flow is fully developed inside the pipe the pressure will be uniform throughout the pipe. is it correct? But in CFX post i am getting minimum pressure and maximum pressure . How it is possible ? Please find the attachment. Kindly reply me what is wrong . |
to drive the flow from inlet to the outlet (or two points with similar velocities) there should be some friction headloss in between, this will create the pressure difference.
