Transparent Boundary
Old   August 3, 2010, 04:04
Exclamation Transparent Boundary
Philipp
Hitch8 is on a distinguished road
Dear CFX experts,
I'm modeling the radiation exchange within a cavity at high temperatures. The cavity has a opening at the top. I'm not sure how to define the boundary conditions at the opening that radiation emitted inside the cavity is lost trough this opening. Should I use the option "local temperature"?
Thank you very much in advanced!
Philipp
Hitch8 is offline   Reply With Quote
Old   August 3, 2010, 14:03
stumpy is on a distinguished road
No, local temperature would mean that the incoming radiation is based on the local fluid temperature at that boundary. You should set an External Black Body Temperature and specify the far field temperature.
stumpy is offline   Reply With Quote
Old   August 4, 2010, 02:33
Philipp
Thank you very much Stumpy!
One more question: What would be the best way to model a transparent window (emissivity = 0, reflectivity = 0.06 and transmissivity = 0.96)?
Regards,
Philipp
Old   August 4, 2010, 06:30
Is it inside the simulation or a boundary condition?
If inside the domain it should be a solid domain. If you are in V12 you may also be able to do it as a thin surface/interface. If it is a boundary then forget the window and place whatever gets through the window as the boundary.
Old   August 6, 2010, 09:46
Philipp
It is a boundary. I defined now an external black body temperature.
Thank you very much Glenn!
Philipp
opening, radiation
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
