External Input Data read as Boundary Conditions |
August 10, 2010, 10:24 |
Erkan
Rep Power: 15 |
Dear CFX- Experts,
I am dealing with a time-dependent problem with variation of the Boundary Conditions by time. like Time[s] Pressure Massflow Temperature 1 0.5 1.5 300 2 0.6 1.4 310 3 0.5 1.5 300 .. .. .. .. .. .. .. .. .. .. .. .. 2 0.6 1.4 310 I really don' t know how i can set up this problem! Is there a possibility to read extern data in CFX? If yes could you help me? Or is there another option to handle such problems? Thanks a lot to all uswsa |
August 10, 2010, 22:05 |
Rep Power: 143 |
Use a 1D interpolation function. You will need a separate function for each of pressure, massflow and temp. This is easily setup in CFX-Pre.
August 12, 2010, 03:34 |
Erkan
Rep Power: 15 |
Hi Glenn,
thank you it is working and I hope the calculation will finish well. |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
Application of real data as boundary conditions | mea05ae | Main CFD Forum | 0 | April 13, 2009 10:34 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Boundary Conditions for External Flow | raytracer | OpenFOAM Running, Solving & CFD | 4 | July 14, 2008 12:18 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
