solution problem : A wall has been placed at portion(s) of an OUTLET |
August 8, 2010, 08:20 |
#1 | |
Rep Power: 15 |
hello
i'm dowing a small analysis on CFX, i'm getting unlogical results, and while running the solver, i see this message with each Iteration : Quote:
total temperature 300K the outlet condition : relative pressure : 0kPa any opinion ? |
August 8, 2010, 18:46 |
Rep Power: 143 |
I really should this answer up as a FAQ, it has been asked thousands of times. Do a search of the forum and you will find lots of questions on it. Also the CFX documentation discusses it.
It merely says that you have backflow at an outlet and this is not allowed. To stop it the solver has created artificial walls at the outlet to stop the backflow. Whether this is acceptable or not depends on your problem, but in general it is best avoided. The best fix is usually to move the outlet further downstream to where the flow is fully in one direction. |
UDS problem with wall boundary condition | Alex F. | FLUENT | 15 | September 21, 2015 09:28 |
wall shadow problem | paul | FLUENT | 5 | November 16, 2013 13:46 |
Two Sided wall Problem | Mk1987 | ANSYS Meshing & Geometry | 0 | March 26, 2010 13:37 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Plate Heat Exchanger internal wall problem? | Conor Hill | FLUENT | 0 | August 24, 2008 12:21 |
