August 9, 2010, 03:15 |
Need help with the following error:
Ugly Kid Joe
Rep Power: 15 |
I am simulating a flow over a cylinder, to find the motion of the cylinder due to the vortex formation. After setting up the entire file in CFX_pre, i get the following error:
CFX_SOLVER_BASIC_MP_LIMIT does not exist in the ANSYSLI pool. An error has occured in cfx5solve: The ANSYS CFX solver could not be started, or excited with return code 255: -No results file has been created. |
August 9, 2010, 06:28 |
Rep Power: 143 |
Licensing problem. Talk to your IT people and find out what CFX licenses you have available.
August 9, 2010, 12:32 |
Ugly Kid Joe
Rep Power: 15 |
If the problem is the licence then why am I able to run the tutorial file correctly ????
August 9, 2010, 18:43 |
Rep Power: 143 |
Look like your license is node limited. Your model now exceeds the allowed number of nodes.
August 9, 2010, 19:13 |
Ugly Kid Joe
Rep Power: 15 |
Thanks a lot........I try with the IT dept.
August 9, 2010, 23:13 |
Ugly Kid Joe
Rep Power: 15 |
Hey Ghorrocks... thanx man !!!! It did work.....I re-meshed it but reduced the number of nodes just to check if it was node related problem....... and it did work.......
I reduced the mesh nodes from 72083 to 1941. The mesh quality is pathetic but still the problem is known now. Regards, Black Mamba |
August 14, 2010, 14:19 |
Ugly Kid Joe
Rep Power: 15 |
@ Ghorrocks: I tried a variety of combinations and got the following results:
I tried running a dynamic mesh flow over a cylinder with 402036 elements and 72083 node and it failed to run.It gave error 255. I then reduced the number of nodes to 1941 and element to 9586 with the same mesh type and it gave results. I thought it was the node specific license issue. SO just out of curiosity I meshed 4 different cases (for stationary cylinder) having the # of nodes to be 1900, 72000, 40200, 109565. These case have no UDF written with no dynamic mesh deformation., surprising all worked pretty fine ??? . My question's are as follows: 1.) If the ANSYS license is node specific, then why did it work the second time (stationary cylinder case)??? 2.) The tutorial which works just fine had a mesh with 18442 nodes. 2nd ,3rd and 4th cases have nodes greater than 18422 but still it worked ??? |
August 15, 2010, 06:37 |
Rep Power: 143 |
I don't know what the node count limit is. You will have to chase that you yourself.
Sounds like you are getting a different error with your error 255 run so you can't use that to establish the node count limit. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
[Netgen] Compiling Netgen on Fedora Core is driving me crazy | jango | OpenFOAM Meshing & Mesh Conversion | 3 | November 9, 2007 13:29 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
