Home > Forums > CFX
Floating point Error
Old   August 16, 2010, 06:47
Default Floating point Error
lorf is on a distinguished road
Hi!
Beforehand - sorry that I repeat the often named error message:
ERROR #001100279 has occurred in subroutine ErrAction.
Floating point exception: Overflow
I tried to solve that with many advices from this forum but nothing help so I describe my problem.
I have an airflow-simulation through ramified pipe and the simulation function as long as I take the boundary conditions inlet- velocity / outlet static-pressure but the results aren't useful so I change the boundary conditions to inlet - total pressure & outlet massflow. Now at the 12 iteration the error (see ahead) comes. It is an steady state simulation.
I tried the following:
Change:
1. Turbulencemodel from k-epsilon to SST and BSL.
2. Reference pressure from 0 Pa to 8 Pa.
3. Fluid timescale factor from 1 to 2 & 5.
4. tried a transient simulation
5. change the mesh size (refine and coarse)
but no change
I have no more ideas so I would be glad to hear some other ideas to solve that problem.
Thanks
lorf
lorf is offline   Reply With Quote
Old   August 17, 2010, 14:39
Default Floating Point
Dr. Richard R. Lange
DukeLeto is on a distinguished road
CFX can be fairly senstitive to initial conditions. Make sure you are setting something reasonable.
If your problem is violent in nature (i.e. supersonic or transonic) you should most likely ramp up the total pressure from a low to a final value over perhaps 100 iterations. The number of iterations is available for use in expressions. See the CFX documentation.
DukeLeto is offline   Reply With Quote
Old   August 17, 2010, 18:57
ghorrocks has a spectacular aura aboutghorrocks has a spectacular aura aboutghorrocks has a spectacular aura about
Overflow errors mean your numerics have diverged big-time. Your model is too unstable and you need to improve the stability.
Some hints, in approximate order you should try them:
* Check the simulation setup is correct.
* Start the simulation with very small timesteps and only increase them back to normal values once it is converging consistently.
* Use the double precision solver.
* Switch to upwinding for the spatial differencing and first order time differencing if transient (but note this is inaccurate and you should go back to accurate differencing for the final run to convergence).
* Ramp the boundary conditions up to make the startup easier.
* Improve mesh quality
* Do an initial run on a coarse mesh and interpolate this to a finer mesh for an initial condition.
Thread Tools
Trackbacks are On
CGNS Compiling Diego Main CFD Forum 16 November 6, 2010 04:50
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Floating point Error message Jonathan FLUENT 2 January 16, 2007 04:07
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
