August 19, 2010, 09:10 |
measure flow through a hole in cfd post
name
I have a problem in CFD post. Inside my fluid domain, I have a structure which has two holes for an opening. I want to compare the fluid flow of those two holes. I could use an expression to evaluate the mass flow. However I dont have a location (plane, etc.) for those two holes. Is it possible to select create a location for the hole? The geometry looks something like this: Code:
August 19, 2010, 18:26 |
Rep Power: 143 |
Yes. It is a bit clunky but it can be done. You need to define a surface to integrate the flow over somehow - options include planes with limits, contour surfaces or I think you can import XYZ points as user surfaces. Then use the function calculator to get the flow rate (or whatever you want) across the surface.
August 20, 2010, 05:19 |
name
thanks, that helped. now i can calculate the massflow with an expression, but how could i calculate the heat flow?
August 22, 2010, 18:29 |
Rep Power: 143 |
use the function calculator to get the heat flux integrated over the surface.
August 23, 2010, 03:20 |
name
but it says that the variable is not available on the plane. is it in general only available on boundaries and interfaces, as it says in the help or is there a chance to use it on planes?
August 23, 2010, 07:36 |
Rep Power: 143 |
Sorry, I meant general heat flux, not the variable heat flux which is only at the walls. Integrate the enthalpy.
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
mass flow rate (CFX post) | sanchezz | CFX | 2 | January 14, 2010 06:54 |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 06:41 |
CFD method for High Re flow | Toshiyuki Arima | Main CFD Forum | 3 | May 29, 2001 11:18 |
