Home > Forums > CFX
Multiphase, how to change my simulaiton to "transient?"
Old   August 19, 2010, 18:20
Smile Multiphase, how to change my simulaiton to "transient?"
max
zmaxcomputer is on a distinguished road
I have a simulation with 3 particles, and i would like to figure out a way to see if i can get some to "stick" to the wall of my vessel. I changed my wall interaction from "Equation Dependent" to "Wall Film". However, i can not see to fix this error. I have changed every valuable imaginable. Any ideas? I can upload screen shots if that would help anyone...i just dont know what i would upload.
Thanks a lot everyone! Ive been trying to fix this for a while......
"Simulations involving the particle wall film option are only allowed for transient simulations. Please change your setup and rerun the case."
zmaxcomputer is offline   Reply With Quote
Old   August 19, 2010, 18:28
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Only use the wall film model if you actually want to model a film on the wall.
If you want your particles to stick to the wall simply use a restitution coefficient of 0 on the wall you want it to stick to.
Old   August 20, 2010, 05:02
Smile
max
Hi!
I selected "default domain default" and switched from wall film to "equation dependent". Where it says velocity i selected perpendicular coeff to 0, as well as parallel coeff to 0. Minimum impact angle, erosion model, mass flow absorption and particle behavior were not selected.
When i run it (and there are no errors!) i am able to get to CFD-post but when i run the animation the little balls still go all the way through, they still dont stick.
Am i doing something wrong?
Thanks again!
Old   August 22, 2010, 18:28
Yes, you are doing something wrong. Turn the wall film model off! Wall films can absorb and emit particles and so appear as if the particles are bouncing off.
Also note you set the restitution coefficients per wall area so if you have multiple wall areas you will need to set it for each wall.
Old   August 23, 2010, 00:26
Smile
max
I did that, and after a bunch of simulations i noticed a few of the particles stop, but only after they hit the wall, then they roll for a while, then stop....then they disappear. Is there a way to fiddle with the settings so that as soon as the balls hit the wall they stop immediately? And stay there so i can count them?
Thank you very much for your time!
Old   August 23, 2010, 07:33
If you have the restitution coef set to 0 then they are not hitting and sliding. They will be a small distance off and caught in the boundary layer.
Thread Tools
Trackbacks are On
Multiphase flow and Phase change due to heat transferevaporation haghajani OpenFOAM Running, Solving & CFD 86 April 9, 2013 02:49
Multiphase Problem Kelsuis FLUENT 3 January 28, 2010 03:43
Change wall boundary condition in multiphase? Jacques FLUENT 0 November 27, 2008 07:26
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 03:33
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
