August 23, 2010, 03:20 |
sine function velocity - error - help needed
Govindaraju
Rep Power: 17 |
I am useing sine function as my velocity input for my modeling
I need to clarify the following item 1. If I use sine function ( velocity as an input and t is a variable), what type of analysis can I do ? Transient or steady state analysis? I use transient analysis while doing transient analysis the solver gives an error. I dont know where I made a mistake . I request anybody to help me in this regard Thank you in advance Govind |
August 23, 2010, 04:18 |
Lance
Rep Power: 22 |
Yes, you can do transient analysis if you have time as a variable... a time-varying boundary condition doesn't make much sense in a steady-state simulation. And if you want help you have to be more specific, what kind of error do you get and how does your expression look like? Post your .ccl?
By the way, isn't this the third thread you've made about exactly the same thing? |
August 24, 2010, 20:07 |
Joshua Counsil
Rep Power: 17 |
What error are you getting? Like Lance says, we need more info.
August 28, 2010, 09:17 |
Govindaraju
Rep Power: 17 |
Hello Mr Lance and Jose
Sorry for the late reply. I solved the problem .I just bring the mesh model into a different working directory then I tried. The problem has been solved. I dont know what is the reason. Thank you Govind |
Streamfunction? | cain | Main CFD Forum | 5 | July 19, 2012 10:05 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[OpenFOAM] LibvtkFoamso | fred | ParaView | 2 | November 18, 2005 19:01 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
HELP - stream function from the velocity field | Fred | Main CFD Forum | 10 | January 26, 1999 12:58 |
