Conductive heat transfer in porous media
Old   August 24, 2010, 03:05
Default Conductive heat transfer in porous media
Nevel is on a distinguished road
Hi all,
could you please explain how to take to account conductive heat transfer in solid structure of porous domain? I do not know how to make it but it would be possible because the feature is referred in CFX 12.1 Documentation as “Porous CHT domains” beta feature.
Thanks for all replies and advices.
Nevel is offline   Reply With Quote
Old   August 24, 2010, 15:37
Jade M is on a distinguished road
This would be a Conjugate Heat Transfer / One Way FSI problem. I would suggest looking at FSI tutorials. There are good ones in the software. This will involve including the solid domain, of course, and meshing this domain as well. The problems in the fluid and solid domains are linked by adding a solid-liquid interface in Pre. For a well posed problem, there are no longer boundary conditions at this interface, as the interface is part of the solution.
CFX solves for conduction in the solid and passes the interface temperature to Mechanical where the temperature in the solid is recalculated. At the interface, the only boundary condition that can be applied is Conservative Interface Flux. The boundary conditions for the inlet and outlet are applied in the same way that they are applied for standard CFX analysis. To prescribe the boundary condition for the outer boundary of the fluid, in Outline, right click on the default fluid domain, select Edit, click on tab Boundary Details, and apply appropriate boundary conditions for velocity, wall roughness and heat transfer.
Good luck! It took me a while to understand setting up this type of problem.
Jade M is offline   Reply With Quote
Old   August 24, 2010, 18:41
No, I don't think it is an FSI thing so I would not look at those tutorials. It should be just a CHT thing.
If you are having troubles getting a beta feature working it is best to talk to CFX support as there are frequently a lot of undocumented things which are important to get it working.
heat transfer in porous media Miko Siemens 10 February 16, 2022 07:13
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
heat transfer with porous media gokul FLUENT 0 February 24, 2009 13:43
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 05:13
